Hi,
Apart from building the Upshur I am wanting to build a simple unusual engine as a gift for my dad, I downloaded some plans for a Jan Ridder Stirling, after looking at these plans for a while I came across more plans from Jan, a flame eater with internal head valve...
Now this looks like a very simple engine to build and should not take to much of my time to complete, so I am thinking one of these will do the job. Had a good rummage in the bits bin and apart from the flywheel I have all the materials needed, or so I thought. The internal valve and piston are to be made of cast iron, no problem I have some that will do the job. But it the cylinder I am having problems with. On the plans it says "Steel", no problem I have a length of bright mild steel (EN1A big enough to make this. But then I came across Jan's web site, in the text, he says he used cast iron or he says you can use rust free steel (assuming he means stainless) all to do with low temperature expansion coefficient.
Do you think the Mild Steel will work, or am I going to run into problems..?
I have emailed Jan, but no response yet.
