Material choice
Dalee
Hi,
I'm building a Paddleduck. I want to make the cross heads and they are supposed to be made from brass/bronze. I don't have a chunk suitable to use.
Friction and sticktion has me wondering if I can substitute either steel or maybe cast iron. Or am I just over thinking?
Thanks!
Dale
Hi Dale,
its not possible to answer if You don't tell which material it is on which the crosshead slides.
Anyway, dont use mild steel n mild steel, that makes for poor wearing properties.
Mike
I used drill rod for the crosshead guides. You could sleeve a steel crosshead with brass (or PTFE) fairly easily.
