Does anybody know how to lay out the master rod for a 5 cylinder so that the cylinders are at TDC at the correct time. I know it is not as simple as a slave rod every 72 degrees.
petertha said:There is also a really good article by Carl Sorensen Jan-22-2008 called Kinematic Relations Between Master and Slave Cylinders in Radial Engines. I got it from the Yahoo R&R forum.
moconnor said:Hello Steve,
I think this topic was covered in some early issues of 'Strictly I.C.' magazine, maybe by Roderick Jenkins? I don't have quick access to them at the moment, so I can't check now. However, if you have the magazines and the indexes, it may be worth a look.
Mike
I have the article from issue 28 in my collection, as I recall it was heavy on the math.GailInNM said:There are three articles listed under master rod design in this index for Strictly IC.
There may be others under other headings.
Index is attached.
Gail in NM
Yes, there is a note in the drawings stating to "trim cylinder height to obtain proper compression"petertha said:I think the Edwards had some sort of head shim compensation? (cant recall)
Excellent news, I look forward to the build. Your constructions are very inspiring.stevehuckss396 said:..when completed, am considering a 5 or 9 cylinder radial.
SKmetal7 said:I can't have a large link rod diameter on the master rod due to a limit on the size of the crank case. I can't have a large crank case, since my lathe only has a 4" chuck
SKmetal7 said:Hey guys! I was the one who originally proposed the question at the CNCZONE, and Steve was kind enough to repost the question for me here.
