It have the same bore and stroke I have reduced to 16mm .If the bore and stroke were the same, with similar compression ratio, and the flywheel had enough inertia to keep the V2 going between power pulses, then it will have more than enough inertia to keep the V4 going between power pulses. If it's a completely different bore and stroke or compression then it may not be suitable. You can always try it and see, then size a replacement based on how it performs.
