Hi Grapegro,
I use propane on 1" bore slow speed (600RPM) engines. Standard RC carbs are satifactory. The needle valve needs to be opened significantly more turns, but they work well. I use Weber "Go Anywhere" portable gas grill regulators (Ebay) on the disposable 1 lb propane bottles commonly found in the US. Their output pressure is fixed at 4" WC (water column) pressure and is more than adequate pressure to the demand regulator. You do not need more than 4-5" WC pressure on the input side of the demand regulator. The output side of the demand regulator runs at a slight negative pressure created by the vacuum signal from the carb. I usually use the smallest throat dia. carbs I can find. A 3mm (.100"-.125") throat dia. is usually fine for a multi-cylinder 1" bore engine for variable speed operation without using a restrictor plate. A restrictor plate is needed only when the carb is too large to pull an adequate vaccum signal on its own. Most slow and medium speed model engines (liquid or gaseous fueled) have carbs that are much too large. Smaller is most always better.
One more thing on RC carbs. Do not use an air bleed type when using LP gas. Find one that is self compensating. On this type carb, the gap between the needle and seat should open more as the throttle is opened, and vice versa. This type carb maintains a reasonably steady fuel-air ratio when opening or closing the throttle, even on LP gas. Otherwise, the needle setting will need to be adjusted any time the throttle setting is changed (even slightly changed).
Also, always build-in a priming button on your demand regulator to allow gas to flow at pressure to the carb. I believe Jerry's regulator design has the priming button. Call it a choke or whatever, it really helps in starting your engines. Once you learn to use it, your engines will start very easily.
Jeff
