little twin from aircon pump
new zealand
hi this is my latest project it is originally an denso airconditioner pump lots more to do but it has good compression and at the right times it will have flywheel ignition (solid state) once i know it runs the overhead gear and supports will be lightened and finned pistons have been machined for oil rings and oil drain holes 10 mill plugs will be used
carb, ignition, and oil pump, cooling (it has a lovley water jacket cast in) to go.
call me daft or a waster of time and the wife wont feel lonley but it has been fun to now
Hello Engineer,
That looks nice! A form of recycling!
What is the capacity of the engine?
The only time I used a "recycled" part, was a crankshaft from an old sewing machine. Makes nice crankshaft for little engines.
Now I wil continue working on the clinders from Mastiff.
Nemt.
What a fascinating way to create a unique engine. Thanks!
BW
Absolutely amazing!! Whare did the cam spend it's first life?
the cams were two old three horse briggs bored up the centre loctited and grub screwed on a central shaft cc is bore 50mm stroke 29mm x 2 =113cc so it wont be a rocketship gears are briggs crank and cam
flywheel and magneto will be modified stihl or ryobi
reason for edit i have measured the cc and have used johnsered blower ignition
