- May 3, 2011
- 415
- 68
Saw a Boxford 125 tcl on the old internet and couldn't resist. As its going to be a while before i get my home build lathe up and running. Thought i would get the boxford to run some bits off till i do.
The 125 has all it's boxford circuits in it and is running on Linuxcnc. There is nothing wrong with Linux, I just dont know how to use it and not prepared to learn another cnc controller just for one machine. So i set about transferring it all over to mach3. managed to get the axis working and the tool changer. spindle turns when told to but only CW. For some reason i cant get it going CCW. It works when running under Linux but not with mach.
with in Linux the is some software that comes with it that you use to setup a profile when you first get your cnc running. it asks you things like..."what is the step pin for X" "what is the dir pin for X". It does this for all function, X,Z tool changer. later on you can go back to this program and select "modify existing profile" you can then see these setting's. problem is, if you modify this file, Linux cant read it any more. was going to use this to find out what the pins are set to. so i could put them into mach.
i did however find another function of linux that would display all these settings in like a VB editor. this is how i got the pin numbers. There is also a .HAL file that you can read as a text file.
(this is getting long)
For the motor the only thing i could find was step pin14, CW pin16, CCW1. mach3 is asking for a DIRpin.
I mach3 i have set the spindle step14 port 1, dir1 port2 (you have to do the port 2 thing as it needs something in the dir) in the spindle control CW m3 output#1, CCW m4 output#2. In the output tab output#1 is 16, output#2 is 1.
there is a cnc4pc C11 BOB in there. this board is controlling the relays for the motor contact switches. the 0-8v is coming from a C6 board. Under linux it was running through a printer port. its now running a USB Smooth stepper.
my other option would be to rip out all boxford boards and replace them with modern stuff. this would cost 200 quid. reluctant to do this as i know it works as is.
any help with this would be great.
