Inside on the HP, outside on the LP.
This minimizes the pressure on the valve rod packing and keeps the vacuum away from the valve rod packing. The only packing subject to vacuum is the LP piston rod.
RPM is high for steam, I use counter weights ( 600 rpm) All the rotating mass and 1/4 the reciprocating....due to 90 degree crank.
A water tube is REALLY sensitive to firing level....ONLY regret
2 gallons of water, 100 pounds /hour.......touchy!
Propane is heavier than air....wood doesn't collect in my bilge, explode and burn my children.....sorry for the graphic but...I hate propane for that reason.
Wood is pretty easy to deal with....and generally won't kill you if you make a mistake with it....can't run far in a 25 foot boat.
My reciever is a tubular construction...with a volume of 3X the HP cylinder volume, or equal to the LP at the point of cut-off.
Yes I did calculations as laid out by Peabody.
I use box links ( Navy style) They hold on to the oil better at high RPM.
I spent some time getting the reach rods flat on ahead and making them long, but not a lot of time. There is about .070" slip.
No real gravity or rod angularity comps other than make the rods as long as you can....always a good thing.
Suspended at center
Link suspension is dead center of radius of link rods.
.008" lead on HP and .016" on the LP. No exhaust lap, not needed with small engines, like under5 hp. 3/4 cut off on both ends.
I tried for equal lead. its easier to measure that.
Design is 2D and only on paper....so not without great difficultly.
