Andrew Pullin
Hi Guys,
My engineering School encourages us to get into our learning by getting our hands dirty
so as such I am putting my extremely limited knowledge to work.
I am designing a simple Wobbler Steam Engine - Bore 20mm, Stroke 40mm for a capacity
of about 12cc. There is about 10mm of overhead for inlet and exhaust ports. The Engine will
probably be made of Mild Steel with 15mm Cylinder Walls (12.5mm on Port Side) and end caps
10mm with a 1mm lip to help seal it. (If it ever ACTUALLY gets built - it is a paper design at present)
The Piston is to be made in two parts each 5mm thick and will be screwed into the Conrod at the
Little End. I have chosen this method so that in lieu of Piston rings I can use a Gasket instead. This
method is similar to Gerry's Beam Engine and the Gasket material is dependent upon Steam or
Compressed Air operation. The Big End drives a Fly Wheel via an eccentric Crank.
Ok, so my question is about the Tolerances for the Piston. If I run the Piston on Compressed Air then
I should not have any thermal expansion to worry about. If however I run it on Steam then I WILL
have to worry about it. The Steam Ports and Exhaust Ports are both 5mm diameter and I am using
a Double Action where Steam will drive the Piston down AND up.
What Tolerances should my Cylinder be turned to? E.g. 20.00mm to 20.05mm
What Tolerances should my Piston be turned to? E.g. 19.90mm to 19.95.00mm
What should my Gasket be made of for Steam or Compressed Air operation?
How big should I cut the Gasket? E.g. exactly 20.00mm
How much and what type of Lubrication will I need?
Since I am designing a Double Action engine, what Tolerance will I need on my Piston Rod
and the Hole in the bottom of the Cylinder Cap? Rod is 5mm in diameter.
Will I need Gaskets on the Cylinder End-Caps? If yes - made of what?
Any general advice.
At present all I have is a Piston and a Fly Wheel design, so no mounting hardware yet.
I have calculated TDC, BDC and the two Mid-Stroke positions and my Pivot point is at
the Mid-Stroke position. My Ports will be fully open and a Deflection of 9 degrees at the Mid position,
and a maximum Deflection of 10 degrees. This puts my Big-End centre tracing out a nice symetrical
eccentric circle that is just off-centre of the Fly-Wheel axle. My Ports should also always be BOTH
Closed or ONE Open to prevent cross-flow leaking.
While calculating I discovered that if I Pivot anywhere else then I get a nice elliptical trace. I am not
sure how I would or if I could connect the Big-End if the Trace is an ellipse. If I can then how would I
calculate where to put the connection? Does it connect to one of the Ellipse Focus Points or the centre
between the two?
Well I hope you guys have enough information to help me out. They say a little Knowledge is
Dangerous so right now I am pretty much Lethal!
Andrew
Any general advice.
between the two?
Andrew
