My lathe, a Chinese made AL 250 is almost exactly three years old. I brought it new and have had little trouble with it. I do not want to stir up the hoary old debate about Chinese made machine tools, suffice to say that I got what I paid for, a fairly robust machine at an extremely affordable price. I had the usual problems that most people experience but a little judicious work with file, scraper and emery paper generally set things right. Lately I had noticed excessive backlash in the apron handwheel and thought that it might be time to give this a bit of a service. I estimate that the lathe has about 2000 hours of operation. Generally I like to keep the machine clean, at the end of the day I vacuum it down to get most of the chips and then a final blast of air in the more inaccessible spots. There is a cover of sorts over the leadscrew and I fondly imagined that this, along with my cleaning would keep most of the crap out of the apron gearbox. As the photos show, this was not quite so. To the casual observer it might look like one hundred years of neglect. On the good side, there was very little wear that I could detect, all the shafts just run in the cast iron holes, not a bush in sight. Most of the machining looked OK, finish and final assembly is what pulls everything down a bit. A good clean, new oil in the gearbox, fix the backlash problem (three loose screws) and back on the lathe, good as new. I cannot see how I can prevent this from re-occurring, I know there are those who will say it is caused by using air to clean down and I can see how some of it can be blamed on this, I accept that. However, given that it is quite easy to remove and service the apron, (it took me less than an hour from start to finish), I intend to do this on a regular basis, say every 200 hours. Cheers, Peter.
