I changed lathes a couple of months (Logan 1825) ago and spent a couple of weeks getting the lathe bed level. I don't have a 'precision machinist's level' but I do have a Starrett 98 (.005"/ft).
Every day or two I would rearrange shims under the four feet trying to get the bed level across the bed. I wasn't worried about lengthwise other than approximate. When it sat still for a few days I replaced the stack of shims under each corner with a stack of not more than two shims and rechecked in a couple of days.
On Tuesday, this week, I decided to take a long test cut and got .006" taper. On checking the level, I found the front right corner low 1 division on the level (about .010" on the width of the lathe) A .010" shim under that corner reduced the taper to .003" and by yesterday it was down to .002" but the headstock end was now out half a division.
Lathe manufacturers emphasize the importance of leveling the bed and I have my lathe sitting on a concrete floor and I have trouble getting it level or to stay level. What do people do with lathes on wooden benches or wooden floors? It is apparent that a small amount of twist can cause big problems.
Maybe my method is wrong. I start with a piece of 2" 6061 aluminum round bar stuck in a 3 jaw chuck. I take a toughing cut to get it round and then take cuts of .005" or .0025" and let it cool before measuring. My reasoning is that 2" with small cut should have negligible spring and I should be able to have 8" or 10" out of the chuck. It is quite easy to change the taper from too big at the chuck end to too small at the chuck end by changing the level of the tail stock end.
Anyone with a good suggestion?
