Hi. I've owned my Seig kx1 cnc milling machine for thirteen years with no real problems. I'm fine with mechanical problems but electronics is a completely different matter. Over the past few weeks I've been experiencing several problems when running proven programs, such as the program stalling during its cycle and the spindle not returning to home when the go to zero tab is clicked. I've also had the control seeming to loose its programmed position and sending the cutter of in a different direction. It was suggested that the problem might be the slide ways sticking, as my machine doesn't have one shot lubrication and I haven't stripped or cleaned the gibs in thirteen years it was a distinct possibility. I've cleaned the X axis slides and gib strip and given everything a good spray of ptfe slideway lubricant. After several hours of adjusting the gib screws I can jog for about three inches in either direction when the cross slide is centrally positioned but jams either side of the central position. I suspect this is due to thirteen years of wear in that area, however the slide moves freely when driven by a spanner rotating the ball screw. So it would appear that the stepper motor isn't man enough to jog the slide either side of the central position. My question is, would simply replacing the existing stepper motor solve the problem, or would it need replacing with a more powerful motor and if so is this difficult? Thanks
