Knuckle head model
rodue
Project of the Month Winner!
The print that I down loaded has a number for a, pitch of 48 and
18 teeth beveled gears #A-1B-4-Y48018, does any one know of and out let to purchase this gear?
Back on the knuckle head I am looking for cylinder rings The print calls for 1.063 by .040 is there a source for this size somewhere.
You may be better off making your own. It can be much less stressful fitting rings to a cylinder than vice-versa.
How's it going and how far along are you?
Terry
I am thinking about a change on pushrod adjusters , It would take a tool that I don't have. What I am thinking is using a square broach. The drawing calls for a small pin to keep it from turning and I haven't figured out yet what holds it in place. I change the adjusting screw to a 6/32. Also on lower pushrod tube the milled groves I can't understand the purpose.
