Guys. I have completed the machining of the piston for the Kiwi MK2 from solid. All is well and I have left the length as 1 1/8inch which is longer than needed.
My question is "how far from the top of the cylinder should the top of the piston be". This obviously affects the compression and Westbury makes a reference to this for the cylinder machining. The engine is only intended for occasional use and will not be used to drive anything.
I would appreciate any guidance
Many thanks
Mike
Many thanks
Mike
