Jerr46
Looking for an outlet for “0” rings for Jerry Howells hit and miss engine.
I all use off the shelf "O" rings for my original an 20% larger farm boy. However have trouble with getting them in the cly {if using the standard} width an depth form the charts. Did you use the printed info for the grove?I get mine at the local hardware store. Off the shelf "O" rings work just fine. I know some people say you need to use Vitron, but I've never seen a difference. I've got several engines from 3/4" bore up to 2" bore and all run just fine on standard "Buna" "O" rings from the hardware store. I built Farmboy sn# 003 and sn #003-x2 ( the double sized one) and never had a problem.
Jim G
