Please don’t give up before trying. Stainless can be extremely useful in the right situation. It isnt much different than trying to machine other alloys like 4340 that can work harden in a flash. So some general machining suggestions:
1. Cut your feet per minute by half vs what you would for mild steel. Frankly I do this by feel a lot of times, I don’t suggest this in most cases. At work anyways I only work on a small range of materials.
2. Keep you feed rates somewhat aggressive. The absolute worse thing you can have happen is to have the tool rub, once that happens you have trouble. What is even worse is that once people create hard spots they tend to try to correct by decreasing feed instead of increasing feed.
3. Coolant /lube is a good idea for managing thermals but you can’t count on it to prevent work hardening. Work hardening is directly related to low feeds / rubbing.
4. Carbide isn’t the panacea that many think it is. I’ve had work hardening in 4340 with new carbide. Again it is all about feed rate. An example here; when facing that slug of 4340 I got some significance can’t work hardening that created the most radical noise. Simply increasing feed rate solved the problem. The first pass with the increased feed rate still had issues through the work hardened areas basically cutting out the hard stuff. The second pass resulted in a nice finish. Now stainless and 4340 machine differently but the work hardening is very similar.
In case you are wondering my theory here is that the cutting action in these materials hardens the material with each pass of the cutting edge. The high feed rates are designed to make sure the cutting edge gets under that hard surface. By high feed rates I mean fast enough to get under that work hardened surface. This will vary some with materials
On low power machines you have options to deal with limited power and rigidity. For example step drill instead of trying to force a large cutter through. At larger sizes boring operations may be a better use of available power. For turning operations use positive rake tools.
After all I have read and considering the limitations of my equipment, it may end up as paper weights or counter weights to my front porch Christmas decorations. Thanks all.
Well if you really don’t want to make use of this windfall, you could send the materials my way
