- Aug 25, 2007
- 3,890
- 715
These are pictures of an inverted hit n miss engine I completed almost a year ago. The engine was designed and built to run on compressed air, and while it runs good, I decided it would be more fun and more exciting if it was converted over to internal combustion.
Currently the engine has a bore and stroke of 1" x 1.5". I plan to make a new cylinder with a bore of 1.25", leaving the stroke at 1.5". I'll also make a new, thicker head and a shorter connecting rod to reduce the compression ratio to around 5:1. New intake valve assembly, new exhaust valve assembly, simple needle valve fuel mixer, new cam, ignition, 10mm spark plug and few other odds and ends should do it. Stay tuned...
