Royal Viking said:I was wondering at what point you would venture into an engine crank case after it had run?
Dan Rowe said:Bob,
You are correct except the jacking gear has to be engaged for safety and turning off the lube oil pump might be a good idea.
Normally the jacking gear is run about 30 miniuts after a shut down.
I spent most of my sea time on 900mm Sulzers.
Cheers Dan
Maryak said:My only foray into crosshead main engines was with 6 cylinder Sulzer RD 68 each of 7000 hp probably a similar cylinder diameter but I can't remember.
