- Jan 4, 2011
- 1,417
- 384
I am getting to the end of my build of the Howell v twin. I am having a problem with compression. I have plenty of compression when I take the head off and put my hand over the open cylinder. I have made a gasket between the head and the cylinder in spite of the fact that Jerry Howell said that it was not necessary. When I put the head on and turn it over I get a lot of pressure and/or suction at the ports without the valves being open. This is even when turning it over slowly by hand. I have lapped the valves using compound down to 400 grit but I still get the poor seal. Since the valves are in a separate cage loctited into the head I even put shellac around the edge of the cage to see if it was possibly leaking between the cage and the head. Still not working. The valves seem to be sealing when I suck or blow through the ports with my lungs. I am running out of ideas.
Some folks have mentioned a tool made by George Brittnell (sp?). Any link to that?
I am still confused as to how the carburetor and the crankcase vent work together but that is a problem for once I get the compression solved.
Gordon
Gordon
