Hello everyone. New guy here eager to learn and willing to take some educated risks.
I am collecting material and parts and pieces for a 52cc horizontal diesel with cross head. It is my first model engine build, but I am ready for the challenge and I hope I am up to the task. A lot of what needs to be done seems fairly intuitive, but there are questions that are begging for experienced answers to help me avoid sad mistakes. Any and all advice will be appreciated. The learning is a big part of the fun.
It seems that material availability is always an issue and many of the design decisions are driven by what you can get that is "close enough." I had planned on having a 1.260" bore, using 1.50 O.D. x .120 wall DOM 4130 normalized tube. Perfect for purchased 32mm piston rings. But the tube arrived with 1.275 I.D., well within the industry tolerances, smooth, round, and ready for honing. But that is 32.39mm, so I guess I need to go to 33mm rings (which I now have) and somehow fit them to the 32.39 bore. I feel that trying to bore the tube out to 33mm would leave me disappointed.
Question 1.
So, do I end file the rings to fit the tube I.D. and then lap them inside a piece of the tube to get them round? With minimal fixturing, it seems quite doable, but I am probably missing something. Is there a danger of ruining the O.D. of the rings with lapping? I can't tell if they have a taper, but the anti rotation notches definitely asign a top and bottom to the ring.
Question 2.
This will be a cross head engine, so no side thrust load on the piston. What material for the piston? I have some Nitronic 60 stainless which has extremely good anti-galling characteristics and should handle the diesel pressures and temperatures without a whimper. It will add some weight, but this is a cross head, so reciprocating weight is already thru the roof, so what's a few more grams. What about aluminum for the piston? I have no desire (nor skills) to cast something from old pistons, but is 6061 or 7075 or 2024 a better choice than the Nitronic 60. And honestly I am only 95% sure that the N60 is indeed that. There is a 5% chance that it might be 316 instead.
Question 3.
For calculating the fit of the piston to bore, I am planning to use a 500 degree F temperature differential between the piston and cylinder wall (water cooled) to make my clearance calculations. Is that a reasonable approach? And what should the final "at temperature" clearance be?
Thanking everyone in advance for their thoughts on this.
Lloyd
Question 1.
Question 2.
Question 3.
Lloyd
