- Sep 2, 2011
- 1,381
- 370
hi, so this is not engine related but just a fun project i wanted to do for my grand kids. a siren whistle. i did not make the 3d stl files, i just downloaded from thingieverse.
but for this part the holes are drilled around the perimiter at lets say 45deg angles. and for the life of me i cant figure out how to offset my mill so the center line of the hole is in the middle of the disk.
lets say the part is 1" diameter and .125 thick, the holes are .125 dia and angle of the drill is 45 degrees. all just made up examples.
when i set my rotary table at 45 degrees would i offset the drill to the left or right by half the drill bit dia? just trying to figure this out. if i drill in the same spot i would if it were not at an angle hole then the oposite where the drill breaks thru will be way out of place and likely even closer to the parts edge than the top part. i need to figure out the math so that the exit of the drill hole is = / oposite as to the top side of the hole. man this is hard to describe but i hope it my question makes sense.
