compressor man
Ok, the title did not do a good job of explaining my question but I had to fit something into that little box! I am wondering how one determines how large to make a piston for a steam engine bore if you want to incorporate an o-ring in the piston. Here is an example that should make things clear.
Lets say the plans call for a 1/2" bore with a solid brass piston. I want to use a piston/o-ring combination instead. How large should my piston be and how in the world do I determine the diameter of the o-ring and how deep should the groove in the piston be for it? I have tried this in the past a few times by just eyeballing it and never really had good results. Is there a rule of thumb that I do not know about that would be helpful?
Chris
Chris
