Ok,
Let's go the other way. Below is a short video of one of my casting pours.
I'm not trying to be stupid here.
Review and let me know what, if anything, I'm doing wrong. (I already noticed my arms were bare and I wasn't wearing a jacket. So you can skip that critique.)
...Ved.
Your setup looks pretty good.
My recommendations would be:
1. If that is uncoated ceramic blanket, you should spray on Satanite so that you don't get fibers in the air.
General note to all: Once you inhale ceramic blanket fibers over some period of time, your lungs are ruined forever.
2. I like to use a crucible retainer, since I had a #10 crucible full of iron slip out of my pouring shank in mid-pour.
I had an initial crucible holder design, but that design failed even though I thought it was a good design.
I redesigned the holder so that it would adjust down on the top of the crucible, no matter where the crucible sat in the loop, and that works well.
Some folks use a crucible retainer, and some say you don't need one, but I did have a crucible flip out that was full of iron, so I know it happens.
People will tell you sometimes that you don't need stuff, and you can find out in a very rude way that yes indeed, you do need it.
3. I have not seen anyone pour from that direction, so I assume you are left handed?
Your pour technique is not bad.
You have the crucible down very low, which is good in keeping the metal velocity low, and avoiding the waterfall effect which entrains a lot of air into the pour.
In some pours, you are a little slow on getting the spure filled, and so you can sometimes aspirate air if you fill with a partially filled spure.
4. Rough surface finish is most often caused by pouring too hot.
Aluminum is generally poured in the 1,350 F range.
If you don't have a pyrometer, watch the miniscus at the wall of the crucible.
When the metal miniscus goes flat, pour immediately.
5. I like a handle on one end or the other of my pouring shank, and I have the handle pointing straight down when the crucible is upright and level.
The handle gives the leverage for fine pour control, and the vertical handle puts the wrist in a natural position to apply force, as opposed to a sideways handle that puts the wrist in a very awkward position as you pour.
6. I had a furnace with a hand-removed lid (before I got my lid lifter completed), and I got ridiculed for not having a lid lifter.
For aluminum pours, you don't need a lid lifter, and the manual lift works fine, and keeps the furnace simple.
I bought a round metal bbq grille at the hardware store, and I set the lid on that, which was elevated off the ground a bit, and that worked well.
7. I have not tried a lost PLA casting yet, but your investment castings look very good.
Not sure what happened with the metal.
I use aluminum 356 ingots, which is the aluminum alloy used for casting.
Some of the other aluminum alloys don't seem to work as well for casting, but I can't tell you exactly which do and don't work.
Everybody has to learn as they go with casting work.
I knew absolutely nothing about foundry work just a few years ago.
I made mistakes, and learned as I went.
I also asked a lot of questions from those who were making successful castings.
My approach was to solve one problem at a time, such as learning to tune the burner correctly for an iron melt, learning what sand to use and how to mold it, learning how to get a good surface finish, how to avoid inclusions and air aspiration, etc.
It is a multi-step learning process.
You are well on your way, and making some impressive pieces.
I really enjoy watching other's casting videos.
I watched all of your foundry videos.
Its is a fantastic hobby in my opinion, and so very handy when you need an engine part.
Good luck.
Pat J
Edit:
I use to post my videos on ytube, but moved them to Vimeo, and I don't think anyone sees them there.
But some of the experienced folks use to watch my videos, and the comments were often harsh.
I look at all criticism (good and bad) as helpful, as long as the criticism can be used to improve the casting process.
Some folks are crazy and just enjoy launching personal attacks in the comments.
I ask the crazy folks "Show me the castings you have made, and lets comment on your setup, your castings, and the progress you have made in the last year". Sometimes the armchair guys who say the most are the ones who have done little or no foundry work at all. That is life I guess.
