G'day guys, I thought I would share my method of making piston rings, I have not heard this technique discussed in any the forums, but then again I don't get out much, so it very well may have been.
In 97' I designed and built my own 7 cylinder radial, the heads were inspired by the Hodgson engine, but the rest was all mine.
The engine runs really well, still even today.
The piston rings were made from a good grade of close grain cast iron using a method a local Aussie model builder showed me in person, this before the internet! No heat was used. So no distortion and perfectly round rings using this method.
The method starts by parting your rings off to near width with good meat on the OD and ID. Then in the mill, the ring gap is machined to the desired size. Over to the lathe you make a simple turning fixture with a face clamp that holds the newly milled ring gap closed. I made a tapered sleeve to gently tap over the ring to close the gap, clamp the face then tap the sleeve off, then simply turn the OD of the ring to your desired bore size.
The ID is turned to final size in the same way only with an OD clamping fixture holding the gap closed. I'm sure you get the idea.
I used some fine sand paper on a flat plate with some WD-40 using a figure 8 pattern to give the rings a nice smooth surface on the faces.
These rings worked great.
Each to their own but after using this method I would never consider using any heat to make piston rings.
I've included some of the parts here, folks may find these of some interest.
Cheers Paul
Cheers Paul
