metrogdor22
- Jan 8, 2017
- 14
- 3
I mean the kind used for rod/main bearings in engines. My first thought is a piece of tube is turned to inner and outer dimensions, then cut in half with a saw. But then it's no longer perfectly circular because you're missing the tiny bit (thickness of the saw blade) from the center, so you wind up with an oval. I suppose you could cut the tube lengthwise, use some kind of collar to hold the halves together, then turn it to size.
How do you guys do it in your shop?
