student123
- Oct 31, 2009
- 183
- 0
I'm on my first engine build, the 'brassy babe':
http://www.davegoodfellow.com/plans.pdf
steam wobbler, I'm using mostly aliminium.
When I measure the internal diameter of the cylinder, moving the digital calipers around the internal circumference , the readings vary from 5.0mm to 5.3mm. (I may also be tilting the calipers slightly
causing measuring distortion).
Assuming accurate measurements, is this cylinder likely to work , or do I need to try again?
Also any tips on getting the piston to fit snugly would be welcome.
Mike
Mike
