Hi all
This is one of the few (3, one is dead, the other close to be...) steam engine (that never really ran on steam, just air) I build.
This one is a double acting compound engine that I designed. ( the others engines are personal design too, never worked with plans for engines, yet..)
Here are few specs
Hp cylinder .625 in. diam
Lp cylinder 1 in. diam
stroke .75 in.
Crank made from solid stock
Slowest idle registered, 175 rpm
Highest rpm @ 100psi, 1500rpm
2 in. brass flywheel, which is WAY too heavy, since the engine will still work without it, but it makes a smoother idle.
The engine won't always start since the pistons are 180° opposed to permit timing of air passages.
Everything runs on ball bearing and at the end of the engine, isn't a pile of washer, but a compressed spring that pushes on a thrust bearing to seal and hold in place the 2 cylinders blocks
and a video i took shortly after finishing it ( about 1 month ago )
[ame]http://www.youtube.com/watch?v=Rkd7B2p0W94[/ame]
Any questions are welcome since I might have quite a few for you !
Deckel
Here are few specs
stroke .75 in.
Deckel
