After a few major setbacks with the Peewee project, I put it aside and decided to work on a CNC milling machine.
I started with a cheap compound milling table (first pic). I tore the screws out of it and fitted some 5/8 ball screws and a pair of 300 Oz steppers. The cheap ball nuts were emptied out and some quality .125 balls were loaded into the nut for a .0005 backlash.
X = 12 inch travel
Y = 7-1/2 inch travel
The frame was fabricated from some 3" angle iron. The column is a 3/4 inch thick plate 12 inches square with a 4 inch i beam welded to the center.
The Z axis is an aluminum box (trammable) with 2 linear rails and 4 trucks. There is a plate that rides on the trucks that has a grid of 1/4-20 holes in it so anything can be mounted to it.
Z = 6-1/4 inch travel
Right now the Z axis has a plate mounted to it with a R8 spindle and a 1/2 horse DC motor that is variable speed. In the future I plan on a 30,000 RPM spindle for fine work.
The cube was the first thing I made when finished with the mill. It is a 2" square.
The total cost of the mill less the computer and software was about $1200 and everything totaled i'm at $1485. I think that may be cheaper than a conversion but a bit more work.
The lathe is next!!
X = 12 inch travel
The lathe is next!!
