ddeal
Hello folks, I just started to work on the Holt engine and I already made my first mistake. I drilled my centers in the ends of the steel rod slightly off and now there is about 0.005" of runout on the bar. This was partially due to the fact that my lathe chuck has about 0.002" of runout and I don't have a dead center for it. I'm thinking I might have to get one
My first question is, Is this a significant amount or can I ignore it and move on?
Secondly, if this is too much to ignore what is the best way to fix it? I already turned the outside to final diameter and one end to the final diameter so I can't just take a cut to true it up. I was thinking that if there is any room to play with on either end of the crankshaft I could just shorten it about 3/8" and drill a new center.
If this is unfixable it isn't a huge loss. The material wasn't very expensive so I could just start over.
