seadragonfoundry
- Sep 9, 2012
- 65
- 67
I will shortly be starting to build a Hoglet V twin to the Randall Cox design. Reading through the plans, the carburetor specified is an OS 10, which has been superceded. Can any one suggest a replacement for this, or another that will do the job? Or perhaps an alternative set of carburetor plans? I have built a number of single cylinder engines but not a multi. One further question, the plans also specify viton o rings for the piston rings. I have not gone down this path before and while I understand that it works I am a bit of a traditionalist, has anyone used conventional piston rings successfully or is this a No No?Thanks for your help
