excelfreak
- Jul 19, 2013
- 22
- 6
Hi all,
I have been lurking here for a while now and have gotten some valuable tips and tricks (I am a complete noobie) as well as major inspiration from some of the completed projects that some of you have posted here.
One of the "problems" is that you all make it look so easy, which it is - if you know what you're doing. I have found out for myself that "knowing the path" and "walking the path" are two entirely different things.
I have always been fascinated with little engines and mechanical devices, I am pretty crafty and good with my hands and a while back I stumbled over Steve Hucks post building the Little Demon V8. I must have read that thread a hundred times - it was the coolest thing I have ever seen, and neatly described all the steps. I thought to myself - I can do this. Oh man was I wrong.....
I got myself a little Sherline lathe and mill, and even bought Steve's plans. I realized that this would take some time (several years) but I have perseverance, so that wasn't a hurdle.
I have never worked with metal before so this is all new to me. I had to learn about feeds and speeds, tramming, setups and pretty quickly I got tired of cranking those tiny wheels by hand. So I decided to convert the machines to CNC, mistakenly thinking that once I "have that" all I have to do is draw the part and hit a button. Yeah - clearly wrong.
So I peddled back - severely - to baby steps and made a wobbler, and another, and another. They keep getting better but I still have many things to learn. I find that I mostly use the CNC capabilities "manual", i.e. no written g-code but the lower z to a certain level and then have it feed in x direction. Or alternatively on the lathe, set a x and then have it move along z to turn a shaft etc.
There is just so much to learn from CAD to CAM to the limitations of the "laughable tiny" machines that I have. Regardless, it has been an incredibly rewarding journey so far and I learn new things every day. Eventually - one day - I will have build that little V8 but it is going to take much longer than I ever anticipated, but I don't mind. Every mistake makes me better the next time around.
So thank you all for the free education you are providing me with. Some of you are masters and artists and make it look so easy. I just hope that at some point in time I will reach a tiny fraction of your abilities.
Thanks for this forum and all your contributions.
Excelfreak
Excelfreak
