vascon2196
- Oct 2, 2009
- 1,026
- 312
Hello everyone...I am two weeks into building Henry Ford's first stationary I.C. engine. I've always wanted to build a I.C. engine and decided to build Henry's first and go from there. I am going to try and stay as true to the original design as possible changing only a couple of things. I am purchasing a nice flywheel casting instead of an old lathe handwheel and the ignition source will be an NGK-Cm6 spark plug instead of the homemade tungsten/brass version that Ford used.
Here are some pictures I have taken over the past two weeks.
Hope you like it.
Chris
Centering the 1" pipe plug to help establish cylinder height
Boring back of 1" pipe plug to accept an aluminum plug
Boring one end of 1" pipe nipple to accept an automotive freeze plug
Finished 1" pipe nipple with freeze plug loc-tited in
Centering 1" pipe tee in four-jaw and boring out for cylinder
Cylinder cut oversize and ready for facing to finished length
3/4" NPT and 3/8" NPT pipe taps and (expensive) tap drills
12V ignition coil
Globe valve / stop and waste valve dismantled
Valve body and valve bonnet ready for modifications
Here is the original engine I am going to TRY and replicate
Hope you like it.
Chris
12V ignition coil
