Don Pittman
- May 18, 2018
- 10
- 1
Hi I've done some research and forum searching but having difficulty finding needed info.
I'm wanting to attempt to cut an internal gear on a small lathe using a slotting device attached on the carriage. I want to use a single point cutter bit. I can't seem to find Info regarding how to get the right profile for this task. I know Info regarding an external gear tooth profile is easy to come by, but for the matching internal tooth profile I am lost. I want to cut a Module 0.5 72 tooth internal gear.
I have the book by Ivan Law "Cutting Gears" but it doesn't address my problem.
Can someone direct me? Probably any advice will be helpful.
thanks
thanks
