I have to cut a thread M35x3 on my Schaublin 102 VM. The heaviest I ever did, with some trouble , was a 1,25 mm pitch so a 3 mm pitch is a challenge. The traditional methods to cut a thread all end up with 3 mm facing the tool.
So I decide to try cutting the groove in layers:
Basically when I advance in x - steps of 0,05 mm and in y - steps of 0,09 mm the resulting feed will be 0,10 mm under an angle of 29 degrees, which is fine. To actually do it I found it useful to draft a cutting schedule. My thread has a flat top of 0,5 mm wide and also a flat bottom of 0,5 mm wide, giving a depth of thread of about 1,65 mm. This I decided to do in two layers. I have ground my 60 degree thread cutting tool with a flat top of 0,5 mm. The resulting cutting schedule is:
The thread I have to cut is an inner thread. I decide first to cut two outer threads to try out the difference. The first picture is the thread cut by the traditional method of advancing the tool by half the thread angle minus a little bit. I used a 60 degree sharp tipped tool. Beyond a depth of about 1,0 mm the forces on the tool pushed the tool back. After the last cut I did try to compensate for this spring-effect by cutting again with the same settings. A full five times the tool kept cutting while veering back to the correct position. The effect as you can see is that the resulting thread has become quite sharp. The thread flanges themselves are fairly smooth for the purpose of this thread.
Doing the layered cut felt in the beginning cumbersome, but the cutting itself went quite smoothly. Every once in a while I did a second cut with the same settings and I found hardly any veering back of the tool. At the end the 0,5 mm wide tip of the tool caused some chatter. The thread profile came out as planned. See picture.
For my light lathe both methods will probably work wit some adaptions. I think the traditional method will work if I re-cut with the same settings e.g every second cut. The layered cut which felt much smoother in execution wil probably work fine if I grind my tool with a smoothly rounded tip instead of a square tip.
