- Oct 20, 2010
- 913
- 132
What began as a way to HT a couple of parts, has grown into a small HT oven and stuff to go along with it.
Seems the HT companies all have a minimum charge $120 or so to HT up to 80-100 lbs.
If you would like a couple pieces HT give me a note, and we can work it out.
Limited by size 6" wide 8" long 4" high. Materials will only be steel, 4140, 4130, O-1 D-2 other tool steels.
After Heat Treating, The work will be black, I use decarbonizing coatings, Depending on material, the coatings will be easy to difficult to remove. Media blasting works great. Depending on shape the is sometimes movement of the piece, Resulting in Slight warping, in a 8"long bar of O-1 it moved about .002, final grinding took care of that. Parts can be remachined with Carbide tools, But tapping is near impossible. Turning hardened parts need shallow DOC and fine feed, but the finish is brilliant.
