mklotz
If you use the SINEBAR program available on my webpage, you may want to download the new version that was put up there today.
SINEBAR calculates the stack height needed to set a sinebar for the angle input by the user. It then calculates the gage blocks from a typical 81 block set that are needed to create a stack of that height.
There was a problem with the latter calculation. It could, in certain instances, call for blocks that are not part of the standard 81 block set. The problem has been fixed (he says with fingers crossed), and it should now report only blocks that really exist.
