- Jan 4, 2011
- 1,418
- 384
I have just completed putting a transistor ignition system on one of my engines (Duclos six cycle) I seem to be burning out hall sensors. I am using a TIM-6 ignition which I have assembled from components but it is the fourth one I have completed. I have the magnet mounted in the brass timing gear. There is a steel cam mounted on the back of this gear also and the high lobe of the cam clears the end of the sensor by about 1/16". I burned out the first one because I assumed that the ground was not good enough so I moved the ground wire to the aluminum bracket which holds the sensor. I got the engine running for about one minute then it died. There is a LED in the circuit so I can see when the sensor is activated. After some playing around I discovered that I was not actually getting spark at the plug in spite of the LED. I can get a good spark by jumping the base and signal on the hall sensor but not through the LED. I have been turning it over with a cordless drill because it takes a rather high RPM to get it started. While turning it over I could see the LED flashing and then fading until the LED would not light and the sensor was burned out. I can still get a good spark by jumping base/signal. I have looked at all solder joints and see no bad joints. Is it possible that having the cam running next to the sensor or the magnet passing a steel spur gear (90° from firing position) the sensor is being effected? Any other ideas?
Gordon
Gordon
