Hi all I have completed a Hoglet fitted with single Hall sensor that is triggered by two magnets, and using the lost spark system. The Hogletl is as per the drawings and the gear to which the magnets are fitted is of brass. My problem is I can turn the engine over by hand to set the timing etc and all works fine. I have connected the two plugs to the ignition unit with the shell of the plugs joined together and earthed to the ignition system. Activating the Hall sensor I get a brilliant spark on both plugs as expected. When I then fit the plugs to the engine and bond the engine to the ignition system, I have checked the bonding with an Avo and all is correct. When I then use the starter motor to turn the engine over to start it, after about 10 seconds the ignition system stops working and I find that the Hall sensor has blown. Now the only way this can happen is for the HT voltage to somehow be destroying the sensor. But How as everything is Bonded !!!
Anyone have a answer.
