Grayson Refurb
Sanny
Hi
Starting to go back together nicely ;D
Did not realise how much work it's going to take to get it back together.
What type of oil should I be using to lubricate the main shaft?
Sanny It would be helpful if you put locaton in your sig line or personal text block.
I use Mobie velocolite 1O for my 9' south bend spindle.
Shell has Tona s Series oils that would also work I would go with a 32 for the spindle and a 68 for the ways.
One shop I worked at got the shell stuff by the 5 gallon bucket.
Thanks Tin
I will ask the engineers at work if they have any.
I'm going to have to strip the main shaft as I forgot to put the drive belt on :-[
