Gear cutter size
gearhobber
New Member
Can someone help me find the correct gear cutter size please. T Y :confused: cutting teeth on 14-1/2 deg. .810 OD .750 pitch circle 24 teeth & 1.560 OD 1.500 pitch circle. 48 teeth Thank You
You have not provided enough info. You can get gears with a PD of .750 in 7 different diametral pitches, 24,32,48,64,72,80,96.
You need to provide DP and number of teeth.
OD and Pitch Circle should give the approx tooth depth. Should be enough info to narrow it down.
OK sit down. Looks like you will need 2 cutters for the tooth counts you are looking at. 32 pitch #5 $60.26 and a #3 60.26 from McMaster-Carr.
Thanks Dave here is the rest of info. .810 OD .750 PD 32 pitch 24 teeth * 1-560 OD .1.500 PD 32 pitch 48 teeth Sorry Thank You
