Gas steam/air engine CAM
rangerssteamtoys
As promised here are several Pictures of the cam.
Hope this explains how it works. If not , basically what I did is grind off the cam lifters, drill 2 holes through the cam at 90 degrees apart then put screws in the holes. After that I just had to grind the screws till the valves opened at the right time.
well sir you are one clever lad 8) ;D........i like to see the end results of someone thinking outside the box !!!
i hope to see more great stuff from you in the near future.
chuck
chuck
I'm working on a boiler for this engine, hoping to get about 150 psi with a copper monotube boiler.
