steamboat willie
- Jun 2, 2012
- 67
- 7
Hello!
I have modified my X2 mill and fitted it with a power feed for the x axis. To do this I have used a 24v geared motor which seems to work very well. I am indebted to others on this Forum who have done the same modification for their work and suggestions as to how they went about it. My question relates to the power supply. The motor I am using is 24volt, and I have a dedicated 24volt 5 Amp power supply to drive the motor. I am going to place an in-line fuse into the power line for the motor and am going to experiment starting with 1, then a 2 and then a 5 amp fuses. I am hoping to ensure that the fuse blows before anything else does. From my meagre knowledge it is the current that I am sensing, not the voltage and so I think I can use a 240 volt fuse of the correct current rating in the 24volt application. I have seen some comment about 24v fuses and thought that they would not do anything different than the 240 v equivalent.
Could I ask any learned members of this Forum to enlighten me as to whether I am able to use a 240v correct current rated fuse in a 24v application?
Thankyou for your time. Your comment will be most welcomed and appreciated.
Bill.
Bill.
Bill.
Bill.
