Hi All,
Can anyone tell me whether the force from the piston is affected by the size of the piston rod?
For example if you have a 1/2" diameter piston (area .196 square inches) and a 1/4" piston rod (area .049 square inches) is the effective piston area only .196 - .049 = .147 square inches when the pressure is applied to the piston rod side of the piston?
I guess what I want to know is whether the piston rod should be kept as thin as possible.
Thanks,
Alan C.
Thanks,
Alan C.
