This tip given to me recently by a professional spray painter and it works.
There's nothing more annoying than imperfections in the final coat that originate in the undercoat / surface but you didn't spot it.
Here's the tip :-
After applying grey primer - give it a light dusting of black (aerosol will do) - when you rub down, any surface imperfections, dings. pukkas etc show up vividly. All the black rubs off very quickly if everything is in order - its not really any extra work.
If the imperfections won't rub out or you reencounter the base material - then more spot putty and primer is required - but that's a lot better than a tragic final gloss coat that needs the same remedy and new topcoat.
Ken
Here's the tip :-
Ken
