allen56am
- Dec 3, 2016
- 15
- 0
Hi friends, I am in the process of building my very first engine, A Flame Licker Engine, It was a 20cc Weed eater engine, I am making it into a open crankcase and it will have a walking beam overhead to run the slide valve that will be on the cylinder head, My question is, What do you think the Flywheel size, ( Diameter & width ) should be, I will be making it from steel or stainless steel ?
34.56 mm Bore
25.01 mm stroke
1.34252" Bore
0.98819" stoke
Also, The existing spark plug hole in the head is 12.75 mm, Thats all most 1/2" Is this the correct size for my Gas/Flame hole, And should I leave it round or make it square or some other shape ?
Thank you guy's so much...
34.56 mm Bore
25.01 mm stroke
1.34252" Bore
0.98819" stoke
