jonesie said:i have a nylon gear that i would like to make form brass. the fixture that i seen you used the one gear as the indexer to locate the the brass blank to cut. i have a plan in my head but was wondering if anyone had plans or a pic.it was a small block with a shaft through it to mt. the gear and blank on and on one end had a finger to lock the existing gear so you could cut the blank.thanks jonesie
tel said:Do I detect an X2 mod here? ;D
If you're going to do that you might just as well go the whole hog and make a simple dividing head - like this Harold Hall one I did.
tmuir said:I want to make one of them and I do have the book.
You call it simple, and it may be for you but that is more complex than anything else I have made. :big:
Where did you get your material from to make this as I struggle finding any large size stock?
