Hello everyone, what a wonderful forum this is! (Long time lurker...)
I am working on a project and am down to the last few operations; and one of them is stumping me.
I have a plastic (POM) 15T bevel gear, 16MM in diameter and 15MM thick, and am trying to fix it on a steel rod (shaft) with a diameter of 6MM. The bore on the gear is also 6MM.
This has to be a firm attachment, as the rod/shaft will drive the gear, rotating another bevel gear (45T).
That's the other problem, the second gear is also plastic, about 14MM thick, with a bore of 6MM as well. The output torque on that rod will be around 0.2N-m, maximum torque around 0.4N-m.
Both gears have M4 set screw holes.
What would be a good way to attach the rods to the gears? I've heard that press fitting metal into plastic may not be a good idea. The 6MM rods I'm using are round, so there's no flat surface for the set screw to hold though. Would it be a good idea to still use set screws even if they'll only be gripping on a round surface?
I've never fit a gear before, so all opinions are helpful. Thanks!
