JimDobson
- Sep 11, 2013
- 277
- 261
First Test of a DIY Steam Turbine running off a 4" Copper MSM Boiler.
Good looking turbine.
May I suggest using Kynar tubing for a plastic steam line. It's good to 400 deg F. Granted, it's not the cheapest plastic tubing around, but you'll know that it'll handle the heat.
...Ved.
Nice to see another sufferer from "Turbinitus" It's quite incurable you know once you've got it you can't ever completely get rid of it.
Seriously nice little turbine she goes well, you probably don't need the flywheel as the rotor itself will act like one to an extent.
It looks like a Stumph type with straight on steam admission mine are Delaval's where the steam comes in at about 30 Degrees to the rotor axis.
As a fellow turbine nut (see my avatar) I would love to see some more details on this one.
Best Regards Mark
Next step is to make another rotor for that turbine, but with curved "Pelton wheel" styled blades.... Then a third rotor using multiple discs as the Tesla design. But may I suggest you couple-up a small generator so you can develop some power and measure the improvement for each design? Also, try shaping the steam nozzle to an expansion cone (de Laval nozzle) to accelerate the velocity of the steam to sonic speeds?G'day Mark,
As a MKI, there's always improvement to be had in the MKII and MKIII versions
I have really enjoyed this turbine and I do think I have a case of 'Turbinitus' now! Below is what is inside this one.
I didn't see this till today, it's just too kool! I intend to build a turbine in the near future.
https://www.instructables.com/How-T...enest,fairly easy, all you will need... More
Hi Jim,
You may understand the Tesla Turbine better from these instructions. I haven't made one (yet) but understand 2 important fundamentals (from what others have impressed upon me):
- Balance: The rotor must be balanced very well, as otherwise it won't attain high revolutions and will scrap the bearings! This also means a stiff housing and stiff shaft are needed, but with small high-speed bearings... (100,000rpm).
- snip
Best Regards Mark
