Bushranger
Active Member
Hi, all.
I've been lurking around here for a while, soaking up the knowledge. Now it's time for me to have a go at making something myself by having a go at this one: A Simple Oscillating Engine. I consider myself to be reasonably competent with machining and have access to a lathe, mill, drill press and other tools, so that shouldn't be a problem. What is a problem, though, is parts like air fittings, etc. You know, the small brass bits that connect air lines to models. Don't seem to be any in Wagga Wagga that I can find and was wondering where you people get these parts from. I don't think a 1/8" BSP fitting will work, so would probably need 1/16" BSP, are they readily available? Even though this wobbler doesn't need it, I was wondering about copper piping as well.
Anyway, that's where I'm at right now. I'll try to remember to keep taking pics so I can show my progress, if anyone would be interested.
Paul.
Paul.
