pont
- Jan 3, 2012
- 11
- 7
Hi all,
I'm working on my first engine- an EZ. I choose that engine because I don't have a mill and I wanted something simple to start with.
I'm using the metric plans which I downloaded from here.
First the flywheel
Then the crank, I took a larger piece of aluminium and marked where I had to drill. I made a mistake, the first time I marked it, so I made it twice.
Then turned to the required diameter
And another problem- I had chosen a piece with too small diameter.The center of the drill was too close to the edge and the result:
But the problem was solved with some patience.
Now I have to dril the holes in the flywheel and the crank and make the thread.I'll post the pictures tomorrow.
Cheers Petar.
First the flywheel
Cheers Petar.
